Electric wheel wagons
DTK
04-19-2016 16:34:20
Where can you get bushings for bolts in tie rod ends of 5010 wagons? Same as Dakon 1212 ,IH 335 and others. Thanks DTK
George 3
04-20-2016 06:42:41
 Re: Electric wheel wagons in reply to DTK, 04-19-2016 16:34:20
Quoting Removed, click Modern View to see.
Machine shop. I have a 335 and that is how I redid the bushings on mine. Used a short piece of round stock and drilled out center. It was a stronger steel that I used. Do not use AISI C1020 or anything similar as they just wear quickly.
