Author |
[Modern View] |
dgoodman2
04-18-2016 11:55:21
I've been doing some disking with super m. Does great but one thing concerned me. While it makes ride really nice just wondered how often that large seat spring breaks. It could easily send you in tailspin and really not fond of falling in front of or on disk. Is there any remedy for this concern? Or maybe you will just tell me it has never happened and that might satisfy my concerns. Thanks.
BarnyardEngineering
04-21-2016 05:18:16
Re: Fall off super M in reply to dgoodman2, 04-18-2016 11:55:21
I don't know about anyone else but I'm holding on to the steering wheel with one or both hands 99.9% of the time I'm in the seat. If the spring breaks, it's going to be a surprise, and it'll probably hurt, but I'm pretty sure I won't fall off the tractor because my natural reaction will be to put a death grip on the steering wheel.
Maybe some of you guys go through the field doing the Village People Y-M-C-A dance? Might be a good idea to change your driving habits if so.
Fullers Farmalls
04-20-2016 16:13:37
Mine is broke on my H. I need to find a new one. But I still manage to stay on the seat pretty easily. I have long legs though and take it easy. I will be replacing it this summer once I get back up to the farm.
dhermesc
04-19-2016 05:30:16
They do make springs of different weight ratings. After mine broke I got the heaviest rating as a replacement.
fbh44
04-19-2016 02:25:39
I'd recommend it. The danger is not an easy let-down, but a snap, and off you go. Fairly cheap on eBay, I did it, and feel much safer.
FarmallCT
04-18-2016 20:51:42
I wouldn't worry about it too much unless the spring goes down a lot. I know my Farmall H has a pretty strong spring so I'd feel pretty safe using that. I have driven other tractors with weak springs that go almost all the way down. In that case I'd just replace it with a stronger spring or put something inside so it doesn't go down as far. ~FarmallCT
gtractorfan
04-18-2016 17:20:02
Old Minneapolis tractors like a U with the seat way back look like this could happen easier. I drove a Farmall H countless hours and never thought about the seat "letting you down" but I was a featherweight back then.
P I Pete
04-18-2016 16:23:23
Being that I am a rather robust person, I put a knerf football inside the spring, sure helps. Pete
dblair
04-18-2016 14:20:34
put a pull shutoff on the ignition and hook up every time your in the seat , not perfect but it would help
dgoodman2
04-18-2016 16:21:23
Re: Fall off super M in reply to dblair, 04-18-2016 14:20:34
That didn't help my feelings any. Hook in like my boat and life jacket. That's good.
CenTex Farmall
04-18-2016 12:46:16
Replace the spring if it has pits from rust. You could also stand up while plowing, often it's more comfortable anyway if the field is rough.
dgoodman2
04-18-2016 16:24:11
Re: Fall off super M in reply to CenTex Farmall, 04-18-2016 12:46:16
I'm not sure if it is supposed to on 53 super m but my seat won't flip up for standing like some photos I've seen. May just replace it and shock anyway. Thanks.
dhermesc
04-18-2016 12:35:32
The spring on my 300 broke last summer while baling hay - I didn't come close to toppling off backwards but I was nursing a sore tailbone for a couple days. DO NOT attempt to operate tractor without the spring - the 1/4 inch of pad does little to soften the ride.
dgoodman2
04-18-2016 16:22:41
Re: Fall off super M in reply to dhermesc, 04-18-2016 12:35:32
That isn't good. Yea I figured rigid wouldn't be good either.
Janicholson
04-18-2016 12:30:25
could happen, but even broken it is not off the back. Put a cheapfootball inside the spring and inflate to your satisfaction. There are three weights of spring made for it to suit various operators gravitational attraction. Jim
dgoodman2
04-18-2016 16:25:28
Re: Fall off super M in reply to Janicholson, 04-18-2016 12:30:25
I'm going to have to remember that..... Someone's gravitational attraction. And I like football idea. That may be my solution.
glennster
04-18-2016 12:13:29
either an air ride seat
or a home made cab
dgoodman2
04-18-2016 16:26:24
Re: Fall off super M in reply to glennster, 04-18-2016 12:13:29
Either would do the job. Like that chain lift blade.
