Farmall & IHC Tractors Discussion Forum |
M running again---WHY
Author |
[Modern View] |
Ellis Kinney
04-14-2016 13:34:19
Long story short. 6 volt system. Last week I started my M to drag some logs, it ran about 2 minutes and died. It cranked once and fired but didn't run. Then it wouldn't crank, dead. It was getting gas and had a spark (electronic ignition). Battery tested good. I ordered a starter switch from Y.T. I installed it, tractor is starting easy and running well. My question----can a bad starter switch cause a running tractor to quit or is this just a coincidence and something else might be wrong also? Ellis
kevinj54
04-14-2016 13:38:35
Re: M running again---WHY in reply to Ellis Kinney, 04-14-2016 13:34:19
Yer power to the tractor is on one terminal so I would suspect bad connections which you cleaned and tightened when putting the switch in.
Janicholson
04-14-2016 14:51:28
Re: M running again---WHY in reply to kevinj54, 04-14-2016 13:38:35
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
