Company Logo Shop Now
300 Utility
dwag
04-12-2016 18:04:15
Got tractor running now notice Hyd's going over relief with all controls in neutral. I&T manual says "plugged hole in press regulator valve". Hys's ok while hitch is moving or w/remote lever activated w/jumper hose in couplers. What do you think? thanks, john
dwag
04-13-2016 11:08:17
 Re: 300 Utility in reply to dwag, 04-12-2016 18:04:15
Thanks Guys, Screen in P.R.Valve was collapsed and damaged and orifice plugged. Messed with single/double acting adj first.
Janicholson
04-12-2016 19:59:41
The regulator is at fault. There is a screen and a demand/pilot valve with a small hole in it. The diagrams in caseih.com search for parts search by model will get you to the layout. It should be in the first block closest to the reservoir between the hitch control valve and the reservoir casting. If the screen or orifice is plugged it will be on demand continuously. If you must operate the tractor, tie a valve on with the loop in the circuit. Jim
Todd Stauffer
04-12-2016 18:41:17
check the roll pins in your control valves that indicate single or double action if the valve is not in one of these positions it will cause your problems
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
Latest Ad: 1967 Ford 3000 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
