Farmall hydraulic cylinders
jim warehime
04-03-2016 14:56:05
third party image
Are the rebuild kits still available for these cylinders?
Southern Ray
04-03-2016 20:15:05
 Re: Farmall hydraulic cylinders in reply to jim warehime, 04-03-2016 14:56:05
Mine are the rubber or neoprene type cup.
I bought them at the local IH dealer.
That was about twenty years ago.
I paid around $10.00 each.
Mine had a few water craters.
I turned the pipe around to put the craters in the upper end of the stroke.
I thought of filling the craters with JB Weld but wasn't sure of the results.
Janicholson
04-03-2016 18:37:46
Common leather cups (we found some at a well drillers shop). Jim
gene bender
04-03-2016 16:39:18
As far as i know you can still get the leathers for the pistons.
jim warehime
04-03-2016 19:54:38
 Re: Farmall hydraulic cylinders in reply to gene bender, 04-03-2016 16:39:18
Ok great, they are the good cylinders have some more that need a little tlc because of water damage. Need to lightly hone the tube and install ne cups.
