Hello, having an issue with my 240 utility, had a leak on the hydratouch valve on the arms, replaced all the seals on both sides and no more leaks! but no i am having issues with my hydraulics, i got them to go up once, now they will not come back down or do anything at all, im locked in the up position, my question is first, is there a sequence to time the spyders gears inside the valve that operates those two arms, or am i possible air locked and where would i find a bleed location, any help would be greatly appreciated
