340 utility help
Mark W.
03-22-2016 06:49:53
Well I went and did it. I broke the steering arm on the left side that is connected to the power steering. Any ideas, other than ebay, where to find a replacement? Thanks
Kerwin
03-28-2016 07:43:38
 Re: 340 utility help in reply to Mark W., 03-22-2016 06:49:53
I broke one on my 300U and had a local weld shop repair it. That was 10 years ago and never had a problem since.
Janicholson
03-22-2016 13:36:20
With respect, I disagree, a good weld after preparation and deep grooving all around welded with Ni rod and peened as it is layered will be. (I have one Welded that way to this day on a 350U that I broke when I was 16). Jim
Paul in MN
03-22-2016 19:18:24
 Re: 340 utility help in reply to Janicholson, 03-22-2016 13:36:20
Jim,
I have no doubt that you are correct, and I have repaired some cast parts in that same manner. But an old time North Dakota farmer neighbor proved to me the validity of the brazing method. On my 300U I had broken the left hitch vertical link due to side sway not being adequately controlled. He claimed the brazing of the cast metal (cast steel??) would be as strong as original, and he did it for me. 25 years later and that repair is still good. But I did fabricate a lower sway control to hopefully avoid a future failure. With the cast metal, plenty of heat, lots of flux and controlled cooling after weld, it seems that the brass has flowed in between the crystalline structure and given support to the parent metal alongside of the break. Maybe the Ni rod will do something similar, but I haven't seen it yet. It would be interesting to lab test both methods, but it would take some serious test equipment.
Regards,
Paul in MN
(Retired physics teacher)
Janicholson
03-22-2016 20:15:47
 Re: 340 utility help in reply to Paul in MN, 03-22-2016 19:18:24
The tensile strength will be good with the braze. The resistance to bending moment will suffer. The fix is a single point safety failure that ranks up there with jackstands under a vehicle when working. (I lost a principal at a School I taught at in Union City Ohio to lack of jackstands) Jim
Paul in MN
03-22-2016 11:31:55
Find somebody who can braze it. A good brazing job will be stronger than the original cast.
Paul in MN
tom dowling
03-22-2016 18:51:12
 Re: 340 utility help in reply to Paul in MN, 03-22-2016 11:31:55
A good proper weld with the right rod and amps is always stronger than the material being joined.
