I tore this M engine apart years ago and it's been on the back burner for several years now. Fast forward to yesterday I was getting the new pistons in and tightening down the rod caps and thought to myself, normally there is some sort of sheet metal tab you bend over to keep the rod bolts from backing out. I couldn't find any though. I used red loctite and torqued them down but the more I think about it, should I have those sheet metal tabs in here or am I good to go? Also when wiring my main bolt I'm not proficient in if there is an exact way to wire them. Does what I did look ok? Sorry for so many questions and thanks in advance for any help.
