350 head redone, next step?
IndiRon
Had the cylinder head overhauled on my 1955 350. Pistons have some carbon on top. Any suggestions on what to look for, or anything to be done to the pistons or engine since it is accessible before replacing the head?
Kinda tough to answer -
obviously a visual check of the cylinders for scoring and obvious wear (like a pronounced ridge at the top of the cylinders) Measure them if you've got the right tools for that.
How was it running before you disassembled? burning any oil?
I'd probably raise each piston to tdc and do a quick wire brush to get the carbon off - and blast everything out really good with compressed air.
how do you use the tractor? The heavier you use it, the more critical the answer here.
If it's a light/parade use tractor - you've probably got nothing to worry about if the piston's aren't knocking around the cylinders. But if you rely on it heavily... there's a lot you may want to check.
Water was seeping between the head the the block. I had it checked for cracks and went ahead and reworked everything.
if it wasn't burning oil to begin with, I'd probably leave well enough alone. Wait till there's a good reason to do anymore than you have.
