steel wheels same for an H and M ?
Fronts are same diameter but hub bearing and race sizes are different. H rear is 2.5 inch shaft, m rear is 2.75 shaft. The only thing that will interchange is wide front axles whether it be on a h or m use h fronts. You also have early and late style fronts and early and late style rears. Hope this helps. Jim.
