M Farmall on LP using way too much fuel
Author |
Matt Harrington
02-05-2001 09:01:58
I am finally getting the M going in the field but have only done a small amount of work. It has been converted to LP and runs well and starts easy after I put in new points, plugs, distributer cap and rotor. The problem is that within a few hours of running (maybe three 1/2 hours) I am nearly out of fuel. The tank is a 32 gallon tank and I just put in 28 gallons and It is all used up. I cannot find any external leak (no icing and no bubbles when checking with a soap solution). It doesn't appear to leak when the engine is not running either. Could someone explain how the regulator works? Could it have a leak and let a lot of excess fuel run through when running but not affect the running of the engine? I cannot afford to keep spending $37 dollars to run the tractor for 2 hours. Your help and expertise is greatly appreciated.
T_Bone
02-05-2001 10:47:43
Re: M Farmall on LP using way too much fuel in reply to Matt Harrington, 02-05-2001 09:01:58
Hi Matt, You need to buy a service manual as there's alot of adjustments and it will also explain how everything works. Remember propane is heavier than ambient air and will settle at the ground so I suggest until you get every thing running correct, keep your tractor stored outside well ventalated. A regulator is a constant pressure device and takes a higher pressure input to a low pressure output at a constant gas volume. They can be liquid inlet, vapor outlet or vapor inlet, vapor outlet. T_Bone
Andy Martin
02-05-2001 15:36:35
Re: Re: M Farmall on LP using way too much fuel in reply to T_Bone, 02-05-2001 10:47:43
And if it's not factory LP you need a manual from the manufacturer of the regulator you have.
Marr Harrington
02-05-2001 13:40:30
Thanks T_Bone, I have to keep it outside because I haven't got a barn built yet. I just got the land last month. I understand the regulator's function and I think mine takes High pressure gas and makes low pressure gas. I was wondering, and this probably won't work, I have a regulator off a propane tank that I had bought. Could I maybe put this in the line and replace the regulator with it? It may not work because it may not supply enough pressure (it was designed to replace a regulator for a barbeque grill). It might supply enough but then under heavy load, starve the engine for fuel. It is just a guess because I like to save money if possible. Does the regulator off an engine allow more air in under load or is it, too, constant but at a higher pressure?
T_Bone
02-05-2001 15:40:41
Re: Re: Re: M Farmall on LP using way too much fuel in reply to Marr Harrington, 02-05-2001 13:40:30
Hi Matt, no it won't work. BB-Q regulators are good for 125,000btu. It's not the pressure but the volume of gas. The best thing you can do for yourself is buy the service manual before you hurt someone! You need to understand how this system works. T_Bone
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
1935 John Deere BN History - The History of My Tractor - by Alexander G. Knox. My grandfather, Orval A. Knox of Chandler, Arizona, affectionately known as Pa, purchased this tractor new from the John Deere/Caterpillar dealer (now Arizona Machinery) in 1935. It was his first new tractor and his first with rubber tires. He used it on his farm growing cotton, alfalfa, corn, wheat, milo, barley, and oats. My father, Norman L. Knox, recalls Pa putting a mower on the tractor during the day and then
... [Read Article]
Latest Ad:
11-2-34 tires
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
