Farmall & IHC Tractors Discussion Forum |
1066 speed trans assembly
Author |
[Modern View] |
fordfx413
02-20-2016 06:24:45
I'm going to start assembling the speed trans on my 1066. The countershaft nut was originally keyed with a roll pin. It also has the lock washer that keys the shaft and nut together. I got my T/A installation instructions from hy-cap with the T/A. It says " tighten to remove all clearance. Back off then snug up. Nut must be drilled through lower shaft and keyed with 1/8 roll pin." My question is when you assemble the shaft in the case and torque the nut, there isn't much room to get a drill in to drill it. Do you guys have any tips? Thank you
cornerpost
02-20-2016 22:17:16
Re: 1066 speed trans assembly in reply to fordfx413, 02-20-2016 06:24:45
The problem with tightening the beejesus out of that nut is that the shafts flexes a little under heavy load. With no give it will stretch to relieve stress. Point is to get it snug and then some combination of roll pin, tack weld etc to keep the nut from turning.
Dan Robinson
02-20-2016 09:01:11
I always lock it in two gears at the same time first. Then tighten it down with grease behind the nut then take it loose and dry it up with brake cleaner and put a dab of loctite on it and tighten it back up. Tightening it first with grease ensure that everything will be find before you stake the nut whichever way ypu want.
MN Scott
02-20-2016 08:14:23
You can also tack weld the nut too the shaft with a mig welder. Two spot welds and your good to go. If you have to remove in the future cut the welds with a die grinder with cutting disk.
The tractor vet
02-21-2016 07:46:46
Re: 1066 speed trans assembly in reply to MN Scott, 02-20-2016 08:14:23
YEa but what about the next time , then ya get to buy a new shaft because the threads are messed up , drill it and pin it .
The tractor vet
02-20-2016 08:05:41
Yea, it is a pain but ya can drill it at and angle thru the nut and shaft . Now one thing here did you set the T/A end play ?? no more then .015 end play. and then you have to use the correct shim on the lower shaft to shim the gear . You can do a good job or a so so job or you can do a correct job . The So so job will teach you to do a better job the next time . when drilling at and angle, center punch the nut and use a good sharp 1/8 drill bit use and 1/8x1/2 roll pin. I use a LONG 1/8th drill bit to help with less angle . My drill bit is a foot long. also turn the lower shaft to where you can get in closer as on the left side you can get more room then tryen to go in straight down.
fordfx413
02-20-2016 09:42:04
Re: 1066 speed trans assembly in reply to The tractor vet, 02-20-2016 08:05:41
Ok thanks for the tips! I haven't installed the t/a yet, but what ever shim I need to install in behind the t/a the counter shaft needs the same size shim correct? My t/a came with .030 and .015 for the t/a and .025 and .047 for the counter shaft.
The tractor vet
02-20-2016 19:36:57
Re: 1066 speed trans assembly in reply to fordfx413, 02-20-2016 09:42:04
Wow who's T/A did you get ?? the ones i use to install came with more shims then that and they all matched in thickness. Ya just had to watch that you did not shim past .100 , if that T/A needed more then they would send you one made different . I set the T/A in the case dry and used aligning dowel and just put two bolts in and snuged them down and set up the dial indicator and check to see how much i had to shim. Do not take the hose clamp off the T/A assembly while handling it and make sure it is tight .
fordfx413
02-21-2016 06:43:51
Re: 1066 speed trans assembly in reply to The tractor vet, 02-20-2016 19:36:57
I got the kit from hy cap. I can order more shim kits but there kinda pricey. The needle bearing for the counter shaft, and the one in the quill housing look good but I'm thinking of replacing them. How hard are they to renew?
The tractor vet
02-21-2016 07:41:43
Re: 1066 speed trans assembly in reply to fordfx413, 02-21-2016 06:43:51
Replacing them is not that bad if you have a driver that fits inside the bearing and give equal force on the outer edges as you can break the outer part while driving it in pressing is better a large socket a slug with a hole and all thread will work. Having a friend with a lathe helps to make up stuff like that. And the one guy that said to Tack weld the lower shaft nut Nah don't do that as it will mess up the threads Drill it even if ya have to go by a long 1/8th bit . Hy Cap must be getting Cheap as they use to send more shims then that with the T/A , Ya got a stack of paper gskt. matériels of different thickness and several metal shim washers that would stack up to .100 after that ya needed a different T/A assy. Because if you had to shim past .100 fourth gear would not engage properly ..
fordfx413
02-21-2016 11:59:09
Re: 1066 speed trans assembly in reply to The tractor vet, 02-21-2016 07:41:43
Ok. So shim the t/a assembly to get .015 or less, them shim the counter shaft equal to the t/a assembly? I just have a junk it manual that hardly explains anything. I need to get a better manual. Thanks for your thoughts and tips. I really appreciate it.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
Green magazine back issues for sale, in good used condition, some of the covers have mild chaffing. Have years 1991, 1992, 1993, 1994, 1995, 1999, 2000, 2001, 2004 and 2006 years available. 12 issues per year. 10 dollars plus shipping per year.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
