Farmall H Tire Rims and POR 15
gldebr
New User
Anyone coat the inside of the rear tire rims with POR 15? Seems like a perfect use. Unless POR 15 has an adverse effect on the tire tube. Any experience?
I have not used the POR-15 but I have used truck bed liner spray and that works real well
i use it when i change a tube. brush a couple coats on the inside. works good if you have calcium in the tires, keeps em from rusting if you have a leak. i also used it on the bottom side of the mower deck on my hustler ztr mower. works real good, tough as nails too.
