Company Logo Shop Now
CRS...I cant remember what a stand alone engine is called.
lucky2
02-07-2016 08:38:37
I just bought a stand alone engine. looks like a c-60 like would be in a cub. Owner said previous owner pulled it out of a combine. Doesn't seem like it would run any kind of combine. Thinking about selling it because I really am not sure what i'm going to do with it besides store it. I was trying to determine value but can not find any information because I can't remember what they are called. Dad says it might have run a baler or a pump but seemed small even for a baler. Any thoughts as to use and what it is called?
lucky2
02-08-2016 16:10:37
 Re: CRS...I cant remember what a stand alone engine is calle in reply to lucky2, 02-07-2016 08:38:37
47 fivewindow...must have a Chevy pickup? I have a 49 5 window. Neat trucks
We had a cub engine on an irrigation pump. Belt drive.[/quote]
DeltaRed
02-07-2016 16:05:11
 Re: CRS...I cant remember what a stand alone engine is called. in reply to lucky2, 02-07-2016 08:38:37
They are called "power units". They were used on numerous inplements.Mostly balers and small combines.'Cub' units were marginal on power. The C113 and C123(A and C tractor) were much better
jeffcat
02-08-2016 00:29:08
 Re: CRS...I cant remember what a stand alone engine is called. in reply to DeltaRed, 02-07-2016 16:05:11
If I am correct the CUB engine is a C-60 so it is even littler. Around 10hp unless you have a very late production like my 1977 tractor that is supposed to have 15hp.
Owen Aaland
02-07-2016 15:34:41
The 64 combine was one of the machines that was available with either engine.
True Son
02-07-2016 11:47:17
My dad had an IH 64 Combine but it had the 113 A or C engine in it. Worked very well.
Dr. EVIL
02-07-2016 09:58:56
50-T baler used the C-60 engine too. The 55-T baler was much higher capacity and used the C-113 from the A/B/C tractors.
Easy to control feed rates into engine driven implements, just lower engine speed of the tractor pulling the implement. I learned how to drive the neighbor's WD-45 when I was about 9-10 years old pulling a 55-T with the engine drive. Had to learn how to drive and rake hay all over again when the neighbor bought a #37 PTO driven baler.
Denny ('60 Lo-Boy)
02-07-2016 09:13:53
Yes, they were used on combines and balers as well as other applications. They may look small but you have to remember they were running a 42 inch combine. :shock:
lucky2
02-07-2016 09:11:51
Thanks Bob. Are yours c-60s? Yes a cub engine is not blessed with power. They would have come off from something not self propelled. Dad says they had a pull behind combine 42" wide and it worked the snot out of Grandpas John Deere B. A JD B is waaay more tractor than a Cub.
gene bender
02-07-2016 11:37:10
 Re: CRS...I cant remember what a stand alone engine is calle in reply to lucky2, 02-07-2016 09:11:51
You are forgetting the Cub just ran the combine not pull it also
Bob
02-07-2016 08:49:57
"Power unit."
I've got two of 'em (not in very good shape) I was told came of of combines, I dunno, before my time.
That's pretty far off from the 500 to 600 HP engines on big combines now, isn't it!
AJB-830
02-07-2016 10:24:56
 Re: CRS...I cant remember what a stand alone engine is called. in reply to Bob, 02-07-2016 08:49:57
Bob, Yes they came off of combines. My dad had an IH 64 combine that had the C60 engine on it. I think it was about a 1958 model. My dad put a starter on it as he didn't like cranking it. Al
fastfarmall
02-07-2016 19:57:04
 Re: CRS...I cant remember what a stand alone engine is called. in reply to AJB-830, 02-07-2016 10:24:56
that must of been a 62 IHC combine, a 64 came with a 123, and could manhandle that easy. My dad bought a new one in 53.
AJB-830
02-07-2016 21:18:37
 Re: CRS...I cant remember what a stand alone engine is called. in reply to fastfarmall, 02-07-2016 19:57:04
No ours was a 64. I still have the combine and the engine. I believe some of the later 64 combines did have an "A" engine or the 123. Not sure what year our 64 was built as I think my dad bought it used around 1958. I still have the operator's manual and will check what engine is listed. I believe when the IH 76 combine came out that replaced the 64, they all had the 123. Al
Hugh McKinney
02-07-2016 19:19:09
My uncle once broke his arm trying to hand crank a Wisconsin V4 engine on a Deere baler. It kicked back on him.
47fivewindow
02-07-2016 21:12:33
 Re: CRS...I cant remember what a stand alone engine is called. in reply to Hugh McKinney, 02-07-2016 19:19:09
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: 1953 Ford Jubilee SN#70068. I can provide pictures upon request and please only serious inquiries for the tractor. This tractor has been well kept under a shed. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
