560 lift capacity
no real numbers here but it depends on how far the object to be lifted is behind the tractor. the farther it is back from the lift point the less lift force you have. up close, it'll have enough lift to pick up the front of the tractor if everything is in good working order which should be in excess of 3000 lbs. be careful though if you are trying to max it out. uphill and uneven ground add more forces to the equation.
Ok thanks! I wanted to see about getting snowblower to put on the tractor but wanted to do some research before I bought one.
6 ft. on a 560.
