(quoted from post at 19:43:16 01/12/16) I just came across your reply referring to the guide to gasoline engine life. I have that pamphlet also. It was given to us while in Hickory Hills training center in the fall of 1969. About one year later or maybe two, IH put out a lot more information when they went to low ash oil and the rubber perfect circle valve seals on the intake valves and back to the umbrella seal on exhaust valve. (was hard to keep up on seals as they kept changing their minds on both gas and diesel engines). The intake valve guide was changed but you could use old when you machined the guide. They provided a service tool for doing that. I machined a whole lot of guides over them years. Perfect circle, of course, had been using the Teflon lined seal and guide machining tools for years already and I had done a lot of the older tractors using those tools and seals. IH put together a engine upgrading kit, pistons, sleeves, valves, seats , guides, seals, manifold bolts, washers & gaskets and a new distributor. Installed several of those. Made a lot more reliable engine. Original 706 distributor was a 25 degree advance BUT, you were supposed to set the timeing at 22 at full throttle. New dist was 22. Another thing, most every head I pulled, (once I caught on) the valve seats were not tight in head. You could tap them right out. I installed a whole lot of oversize seats. Learned that lesson on in-laws Chevrolet. Local machinist had put in valve seats and that engine burned valves like popsicles. Seats never fell out but you could tap them right out. If that seat does not transfer heat quickly, overheated valve is result. Also, before low ash oil recommendations for gasoline engines, I had a customer torch a valve in a 706, very low hours. Did regular valve job, torched it again shortly. Seat was loose, replaced just that one seat with oversize and it took care of the problem. Easy to test for loose seat. Just a very light tap with tool like screw driver through port and if it moves, you are done. Also, loose seats will often show a slight pitting around the edge of head.
Alot of good information in that post.
I understand that that "guide" is dated. When taking a look through what literature I have-- a couple of different service manuals, some service bulletins, and parts books, it's not hard to see alot was changed (and change was almost constant). I'm not totally sure how complete or up to date my literature is.
One could not possibly explain all of the updates/improvements/alterations to this series of LPG and gasoline engines or the variations between engines and their various applicaitons here. As far as octane demands, no info I have shows any figure other than using gasoline with a minimum Research Octane Number of 93 . I couldn't find the newest service manual I have, but in 1968, compression ratios are all below 8:1, so there's nothing that I would call "high performance" about these engines when "stock". Some were closing in on 3000 rpm's, though.
In 1961 there was a guide of "acceptable" engine oils published. I'd guess it's about 40 pages. In 1964 they changed the oil change intervals to every 100 hours and filter change intervals to every 200 hours for 706 and 806 gasoline powered tractors. 250 hours on an oil change wasn't cutting it. Later IH came out with their "Low Ash" oil, and it seemed to cure or help minimize some of the issues that plagued these engines.
Service bulletins show that the valves, guides, and valve seals were changed several times. Almost looks like valve train roulette, try to standardize this, update that, see if this helps, and try to keep improving. Stellite parts got used in the LPG engines first, and gasoline engines later on. Some of the valve levers were made incorrectly and had to be reworked. Changes were made to piston design, tolerances, and fitting procedure, rings, rings, and some different rings, valve cover breathers were eliminated during 460/560 production, and alot of other changes and tweaks, some large, some small are in the service bulletins.
Parts books show that some of the internal engine parts or assemblies were updated several times. Some of the C-263 sleeve assembly and ring set part numbers are at -R98 and -R99 today.
Over the lifetime of this series of engines, dozens of different distributors/distributor packages were used from at least 3 manufacturers. Distributors, engine timing, and carburetors appear to be pretty much application-specific. Many of the tractor applications had at least one distributor package and timing spec. change at some point. Carb guts got changed on many applications as time went by. Single venturi packages were offered to stop icing and decreased performance when those issues were encountered with a carb with a double venturi. Fuel shut-off solenoids (when used) went through a couple of changes in rapid fashion.
AG
