986 alternator
henryv1111
10-08-2015 05:53:00
The owner asked me to put 2 new batterys in his IH 986 it is a 12V system with 2 12V batterys in parrlell after doing this The volt meter shownd no voltage I placed a meter on the battery and only read 12.4 volts with motor running is there any way to test the alt on the tractor?
Owen Aaland
10-10-2015 15:14:49
 Re: 986 alternator in reply to henryv1111, 10-08-2015 05:53:00
The output terminal and the #2 terminal should have battery voltage on them at all times. #1 terminal should have no voltage with the key switch off. With the key on the #1 terminal should have somewhere between 3 and 12 volts, most often around 6 volts. With the engine running you should see between 13.5 and 14.5 volts on all terminals. If the voltages are correct before starting the tractor and you do not see a rise in voltage after the engine is running the problem is in the alternator.
El Toro
10-08-2015 08:10:40
My neighbor had the same problem on her Ford car and after checking her charging voltage I told her that her alternator wasn't charging. Hal
rustred
10-08-2015 07:37:48
the alternator is not charging. with tractor running you should have about 14.8 volts max. this is only a quick test. to show actual charging amps you need to load the alt. with a carbon pile and it will show you what the alt. is putting out. but regardless it needs to come off for overhaul or replacement.
Allan In NE
10-08-2015 06:09:03
You just did. :>)
Allan
henryv1111
10-09-2015 05:16:35
 Re: 986 alternator in reply to Allan In NE, 10-08-2015 06:09:03
Thank you all for the replys The owner took the tractor saisd he needed it to run the auger they are harvesting corn and soybeans I told himhe would have ot charge the batterys frequently.
