350b case dozer
i just bought a 350 case its runs like a new one i dont much about the little dozer but it has good power in reverse when i go foward sometime it will move and sometime it wont when it does move it dont have alot of power and it also will not turn left or right it just wants to go straight.Ineed some help....
First you need to establish there is enough oil in the shuttle,the oil is checked with the engine running,start the engine,put it on low idle with the shuttle in neutral and the transmission in top gear check the level,top it up with Case TCH or any HyTrans equivalent, see if it drives forward properly now,if not check the linkage for the forward/reverse control valve is moving the valve properly,if that OK and the brakes are off there is a problem with the forward clutch,the discs could be worn,the piston leaking or the most likely and common to the Borg Warner shuttle is the Belleville spring has cracked up in the forward clutch pack,at this point it is wise to have a pressure check before the machine is demobilized,hoping it only low in oil.
Good luck
AJ
Bad as I hate to say it, it sounds like the forward clutch pack in the transmission is worn out. Unfortunately while this is repairable, the cost of the repair (((to do it right with a full transmission rebuild))) will probably be at least several thousand dollars between both parts and the labor for someone to do it. Good luck.
