International 3414 / 3120
mide
New User
I have a International 3414 loader with a 3120 backhoe attachment,I am trying to find a Top Swing Mount for the backhoe attachment,,It goes on the top of the splined swing shaft and mounts the entire hoe attachment to the back of the tractor..ANY info is appreciated ,Thank You
I assume you mean the splined collar on top? It is NOT a mount to hold the hoe on as you mention. It does hold the splined shaft for the hoe swing function.
I don't know if I already answered you on another forum or not. But -there's been one on Ebay for month.
Splined yoke - IH # 468389R11 Splines are 3 1/4” on the OD, 3 1/16” to inside of splines, and 32 spline count.
Im just going by the International Service Manual ,It is named as a Top Swing Mount ,,All is good,,I did find it on ebay on a library computer but for some reason it won't come up on my pc,,
I thank you for the part number and dimensions because the service manual i have does not specify much !
I have 3414/3120 also, leaky o-ring in that same area
thinking of torching the hoe part up for scrap instead of sinking more money into it, tractor loader part I want to keep
located upstate NY west of albany
I might be interested in buying some parts of it. Where are you located? I know there's a 3414 with hoe and loader on the side of Route 30 near Sacandaga. Is that your's? I pass it often and often wanted to stop and ask about it - but never got around to it.
in Cranesville, near intersection of Robb/Baldwin Road, near Mt Loretto
I have the O-rings to fix the leak, how works fine, boom cylinder leaks down slowly, pins not too bad
e-mail is [email protected], have some pics
