TD-14 Starting Problem
Gemdozer is got you going the right way.. Something in the switch over valve not getting right. After it does start does it run good or sputter around ?
(quoted from post at 16:15:02 02/29/12) Gemdozer is got you going the right way.. Something in the switch over valve not getting right. After it does start does it run good or sputter around ?
After going through these gyrations, it runs fine which made me think that the decompression valves were O.K.
