300 MF Crawler loader
(quoted from post at 21:33:25 04/05/11) I am still have some 3366 MASSEY used parts .
Hi Hector
I need a exhaust elbow, I also need a chain for one side. I'll take both chains if you have them. Let me know what all you want to get rid of. Thanks
I am sorry all motor parts and chaines ben sold
am still have for 3366 MASSEY the 2 front idlers,1 sprocket,some transmission parts,final dive and stering cluch
(quoted from post at 10:34:10 04/06/11) I am sorry all motor parts and chaines ben sold
The transmission I have has 2 speeds forward, 2 speeds backwards. What parts do you have?
When I pickup the 3366 MASSEY the transmission was removed from the machine and complet dismantled and I do't know about this transmission but have some gears and shafts
(quoted from post at 18:21:24 04/06/11) When I pickup the 3366 MASSEY the transmission was removed from the machine and complet dismantled and I do't know about this transmission but have some gears and shafts
Thanks Hector
But I don't think I need transmission parts like you got.
I recheck today in my 3366 MASSEY and have some some plates and discs cluchs packs and torque parts and I sold the transmission pump TUROLLA to a guy how has a 300 MASSEY.
(quoted from post at 03:51:41 04/10/11) I have a MF 400 dozer. Is that close enough to have any parts you could use?
I realy don't know how close the 300, & the 400 was. But I need a exhaust elbow, and chains? They both should have a perkins diesel. Thanks for letting me know!
Should be able to get an exhaust elbow from a tractor wrecker. Probably available from Perkins or aftermarket as well. Chains will be hard to find. You might have to convert to more common chains. I think the 400 uses more common chains(rails). The 300 is a 4 cylinder and the 400 is a 6 cylinder.
(quoted from post at 16:43:07 04/10/11) Should be able to get an exhaust elbow from a tractor wrecker. Probably available from Perkins or aftermarket as well. Chains will be hard to find. You might have to convert to more common chains. I think the 400 uses more common chains(rails). The 300 is a 4 cylinder and the 400 is a 6 cylinder.
Thanks for the information. I didn't realize there was that big of difference. Have a great day.
I am looking for the front idler assy for a MF300 Dozer. Are the idlers, shafts, and hanger assys you still have in good condition and are there any casting numbers on them?
