H3 track pads
kipn
In another thread Jdemaris, I didn't want to hijack it, you mentioned that you have extra 14" track pads. Do you happen to have any 12" pads? Any grouser style. Looking for about 5 of them.
I've only got 14" and 13" pads. All high-grouser dozer pads, NOT flat, street-type loader pads.
I can't think of any reason why you can't torch off some metal from the 14" and make them 12". Mounting hole-patterns are the same; the 14" versions are just a little wider.
Pads CAN BE CUT DOWN! Equal amount off both sides . It worked for us. Even filled bolt holes re -drilled 350 pads to fit O.c track chains. pads can be cut with band saw (Boron STEEL PLATES) with no difficulty. Hope this helps.
LOU
Thanks guys. Not in any big rush. CH responded to an email after a month and said he had them. Just not sure that I want to go there though.
