I changed the fluid again. This time I pulled the lower pan off and took out the screen and cleaned it (horrible mess of sludge down there). I popped on a new filter and put in fresh fluid. I got a 5000psi pressure gauge and put it on in place of the pipe plug on the top of the winch housing and it registered NOTHING even in wind mode as the winch spun. I guess that means less than 100psi. At first I didn't trust the gauge and loosed it up until a little bit of fluid leaked and put into wind mode and there was almost no change in leaking rate, the pressure really is that bad.
I guess this means the little webster pump is shot, right? Could it still be the valve or an internal leak at this point? A new pump is $575 from deere and I would consider it worth it to get my winch running, but is there a way to test the pump to be sure that it's definitely the problem?
