Anonymous-0
I put the new batteries in and my skid steer and it started on it's own today, however the electrical power is still lost after a while with both the lights and heater on together. Someone had suggested the voltage regulator could be the problem so I have a couple questions. Is the voltage regulator supposed to get warm? Would dirty connections to the wiring harness cause these problems? I talked with a mechanic and then an auto electric specialist. They both said a loose fan belt would cause the problem I'm having. They said if I can turn the fan on the alternator by hand, the belt is too loose. I will check that tomorrow. If the fan belt is tight enough(I tightened it a couple months ago), would the voltage regulator be the most logical thing to look at next? The auto electric guy said VR's rarely go bad but Thomas had some problems with them when they were new. I changed mine about 3 times but this last one has been in since the late 90's. Do they have points or contacts that wear out? Sorry for all the questions on this. Finding electrical faults is not my specialty. It does frustrate me though. When the power is lost, the alt. light doesn't come on which apparently means it's not an alternator problem. Thanks Dave
