Was doing Spring maintenance checks on my Ford 755 TLB over the weekend. Everything looked good but I removed the hyd oil reservoir dipstick to get a little oil to lube the metal flange of the inner air filter (they're kind of a pain to get back in dry) and can't remember putting it back. It rained last night and supposed to get some more rain this week. Probability is that I DID put it back as there's a lot of things I don't remember doing nowadays and then I go check and find out I did it. :? The TLB is at my property about a half hour away and I won't be back there until Saturday. Hate to make a special trip just to find I put the dipstick back in. Considering the system holds 55 gals of hyd oil and the reservoir hole is maybe an inch in diameter kind of protected by the cab, I wouldn't think a few raindrops would hurt the system, but I thought I'd pick the brains of the forum.
While I'm at it, what about changing the engine oil? Do you guys change the oil religously even on low-use machines? I changed it with a new filter 2 years ago, but have used the TLB sparingly since (maybe 60 hrs, tops). I don't have a problem with doing proper maintenance, but just hate spending money when I don't need to.
Speaking of filters, the inner air filter says "Do not clean". I replaced it when I bought the machine 4 yrs ago and it looks good as new. The outer one takes the abuse and I've cleaned/ replaced it a couple of times. Anybody know why they don't recommend cleaning the inner one?
