Can anyone help me here.....I have a 1979 JCB 3C111, and over the last few times I've been using it, the engine revs have been dying away resulting in obvious power loss. I suspected fuel starving, so I have cleaned the sediment bowl out, cleaned the lift pump gauze and also cleaned the fuel filter (all filled with loads of rubbish), re-bled the system and its exactly the same. The odd thing is that if I turn the engine off for just a couple of seconds, then start back up, she will rev up, but will only hold this for a second or two before it just dies back to a tickover. Its as if the fuel pressure is there, but its starving in some way and when the demand isn't there, the pressure puts enough fuel through to allow a brief rev up but then goes back to its 'govened' state.
Any ideas?
Steve
Any ideas?
Steve
