Anonymous-0
I noticed oil dripping from where all the hoses come out by the swing post on my backhoe. I've replaced most of these hoses in the past because they rub on the dirt when digging deep. I put some of the kevlar? type hose protector sleeve over all the hoses so they wouldn't wear the rubber off the outside. One of the sleeves appears to be where the oil is coming from. A couple of the sleeves will slide and bunch up a bit but I check them and slide them back in place. Have you ever heard of a good hydraulic hose getting a small or pinhole leak? I don't think it's a big leak because everything still works. The sleeve could be holding a lot of oil back. It just a wierd leak and I'm wondering if I just got a bad hose or something. I think the hose is rated for 4000 PSI and I'm only running 2500 PSI. If the oil was pretty hot, could that cause a leak? I'm a little puzzled. Thanks Dave
