fuel pump for T6 IH
Lavoy
08-18-2004 23:15:04
I need a fuel pump for a T6 International. The one we have has had the pump removed. Once you get below a half tank of gas, it barely trickles out the fuel line on level ground.
I am told it is a GM style fuel pump, but I don"t even have the old one to compare it to. Any ideas?
Lavoy
windmiller
08-30-2004 00:41:09
 Re: fuel pump for T6 IH in reply to Lavoy, 08-18-2004 23:15:04
Lavoy, I have a fuel pump off of a T6. It's not new but it was working wen it come off. I happened to find a new old stock one so I replaced it. Email me if you are interested. steptop@webtv.net
Jeff
ALLAN CA
08-19-2004 21:19:46
The engine is the same as the model as in the farmall M and parts are readly avaible. TD 6 is the same as MD tractor as for moter parts.
Lavoy
08-20-2004 08:50:39
 Re: fuel pump for T6 IH in reply to ALLAN CA, 08-19-2004 21:19:46
The M"s did not use a fuel pump, but I have heard that W6 did.
Lavoy
JimInOz
08-19-2004 14:53:12
Hi Lavoy.I don"t know much about the T6,but the manual says the pump is AC Spark Plug Co # 1521676/35008R91 for T6 Serial 501-6887...or #1539555/355008R91 for Serial # 6888 Up.
(first # is AC ,second # is IH ).
I"m sure the Redpower guys will help you out.
