Company Logo (800) 853-2651 Shop Now
JD350 oil pressure
PhilMac
08-18-2004 14:18:18
I have a JD350 and when started cold, the oil pressure is 60+. After it warms up the pressure drops to around 20.
What is the problem?
Thanks
Roy
08-21-2004 22:05:41
 Re: JD350 oil pressure in reply to PhilMac, 08-18-2004 14:18:18
Are you using multi-grade oil ?? I 've run into a problem with some multi-grade oils breaking down causing low oil presure at warm-up.. Try switching to straight weight SAE 30. It might surprise you
PD Mechanical
08-20-2004 05:35:34
third party image
If its 20lbs. at idle, probably nothing. When oil warms you will lose some pressure. Should be around 40lbs. +/- at operating speed when warm. If not then you may have some worn brgs. Probably mains.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
Latest Ad: Two wds. Both run and drive. Sheet metal is ok. One has fluid in the rims the other doesnt. Both have hand clutch and hydraulic lift. Have done some work to both of them. 1,750 for both firm. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
