Company Logo (800) 853-2651 Shop Now
Source for generic hinge pins, bushings, etc. by d
Charlie
07-19-2004 18:43:39
I want to redo some pin joints on my Drott loader bucket and elsewhere and think it might be easier to use generic stock pin sizes, along with various stock bushings and collars, instead of Drott parts, which may not fit my heavily warn bucket joints. Can anyone recommend sources with a good catalog, preferably online, of dimensions available? I thought this would be easy to find, but I did not have much luck searching. Thanks.
danct
07-21-2004 08:26:18
 Re: Source for generic hinge pins, bushings, etc. in reply to Charlie, 07-19-2004 18:43:39
charlie
try Isostatic Industries inc on the internet phone # is800-621-5500 they have a good selection of bushings you can download ,they will give you an adress in your area who will have to order what you need ,i have used them and they make a good product
good luck
Danny
Wayne
07-19-2004 21:01:51
A good source for the bushings is Connex. As you can see from the sight they make hardened, split bushings. Being split they aren't really restricted to an exact size hole although they do have min and max recommended tolerance for the OD of the hole your putting them in. This tollerance will effect the ID making it larger or smaller than "normal". Depending on how bad off the holes are, how true they are to each other, etc, using these can save the cost of having to have the holes line bored. Still depending on what kind of clearance you wind up with when the bushing are in you may have to have the pins custom made larger or smaller than "standard" to fit to avoid having them too tight or too lose.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
Latest Ad: Two wds. Both run and drive. Sheet metal is ok. One has fluid in the rims the other doesnt. Both have hand clutch and hydraulic lift. Have done some work to both of them. 1,750 for both firm. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
