MC starter motor
Tobias
05-23-2004 21:15:40
My starting motor on the MC crawler has quit. I thought it was the switch so I replaced that but its not that, the motor will not go. I hear a faint jtz jtsz when I pull the lever and thats it. Any ideas?
My MC manual does not say how to remove the motor, it refers to the M manual which I dont have. Any one ever remove this? There is a large nut on the RHS and what looks to be a allen key inside of that. Common sense would lead me to loosen it all off and pull the motor out but my common sense typically fails. Please help if you can, I really want to gravel.
Mark
05-24-2004 16:30:05
 Re: MC starter motor in reply to Tobias, 05-23-2004 21:15:40
The allen bolt,lock nut holds the starter in. Loosen lock nut,back allen all the way out,may take some wiggling if starter is rusty. Make sure when you reinstall the starter you line up the allen bolt to the dimple in the starter.
