I have posted this on another board, but it may be more related to Oliver than the "other brand of crawler".....I have been digging rocks with my newly restored OC-46-3G loader, a couple of hours every Saturday, and I am losing coolant. It doesn't seem to happen when taking it easy on level ground but while working hard on steep inclines I lose 2 to 3 Litres in a couple of hours and have to shut down when the temp gauge starts to rise above 180. The oil level and quality are fine - no change in level, no sign of water. There is no sign of any dampness in the exhaust or rough running to indicate water in the cylinders. The water pump seal dripped a little when I first rebuilt the engine but there is no sign of dampness there after fluid loss and no marks from spray off the fan pulley. The only place I see coolant is in the belly pan, up under the rad. I pressure-tested the rad during the rebuild and it was fine at 3 PSI. A friend suggested that I might be getting some blow-by between a cylinder and the water jacket at the head gasket under heavy loads which would build up enough pressure to snort some coolant out under the rad cap when it is nose-down and all the coolant comes forward to fill the rad to the top. (Nose-down is a common position when working hard!). Since it isn't real easy to get at the head bolts to check the torque, I'd like to save that for the last resort. Anybody else got any no-so-obvious ideas about how the coolant might get into the belly pan? Another question: the book says 140 Ft-Lbs for the head bolts - should that be with the threads dry or greased? Thanks gang. (At least on this board I don't have to refer to my crawler as "Brand X"!)
