Company Logo (800) 853-2651 Shop Now
H.D.7 H.D.7G
Jerry Cagle
02-17-2000 19:31:01
Does anybody know what is the purpose of the G in the H.D.7G . I had a request for parts for my H.D.7 & want to know if final drive parts will interchange on the two machines. Thanks. jlc
Lee Bradley
02-22-2000 09:19:03
 Re: H.D.7 H.D.7G in reply to Jerry Cagle, 02-17-2000 19:31:01
The 'G' usually identified the machine as a loader. HD-7 and HD-7W were built from 1940 to 1950 and had a 3-71 Detroit engine. HD-7G was a updated HD-6G (HD-6 loader) turbo AC 4 cylinder, later turbo 6 cylinder AC. HD-7Gs were built from the late 50's through the 70's. As far as I know nothing interchanges between the HD-7/HD-7W and the HD-7G. They are completely different machines. The HD-7W is a wide track version of the HD-7.
Later,
Lee
Mudcat49
02-17-2000 20:18:52
I don't know about a HD 7, but on a HD 6, the straight 6 had manual steering clutches, the G had hyd steering clutches
Jerry
02-17-2000 21:07:16
 Re: Re: H.D.7 H.D.7G in reply to Mudcat49, 02-17-2000 20:18:52
think the final drive parts are the same?? trying to find out if drive pinion shaft is same on both machines. thanks jlc
DY
02-18-2000 11:29:42
 Re: Re: Re: H.D.7 H.D.7G in reply to Jerry, 02-17-2000 21:07:16
I looked in a parts book for a HD-7. Looks to be 3 different pinion shafts. 2 are 12" long, serial# breaks, and 1 17" long. SN break is at 12022
Suspect the longer shaft is for a wide track machine HD-7W.
I probably could get the parts book to Kinko's if that would help.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
Latest Ad: Two wds. Both run and drive. Sheet metal is ok. One has fluid in the rims the other doesnt. Both have hand clutch and hydraulic lift. Have done some work to both of them. 1,750 for both firm. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
