TD9 Diesel problem??
Mark
10-19-2003 13:59:20
I can start my TD9-91 on gas, switch to diesel and it will run good for about 10 minutes then it slowly will start to loose power, 1-3 minutes time for it to loose power. It will eventually stop. I can then hear the fuel in the tank, it sounds like it's boiling. After it stops boiling I can start it up on gas and let it run with the diesel lever on for a few minutes until white smoke starts to bellow then switch to diesel and the process starts over. Any Ideas? Fuel filters are new but I have not yet cleaned the water trap sediment bowl or screen. The injector pump had disel in it I drained that and refilled with oil.
clark
10-20-2003 07:03:08
 Re: TD9 Diesel problem?? in reply to Mark, 10-19-2003 13:59:20
It sounds to me like the fuelpump isnt pumping. especially when you said the fuel in the tank was bubbleing. this is a indication that the checkvalve in the pump is stuck open or worne out.the fuelpump is located on the lower back side if the injector pump tords the starter.
truckbummer
10-20-2003 17:43:03
 Re: Re: TD9 Diesel problem?? in reply to clark, 10-20-2003 07:03:08
Check your cap air must go in as fule is pumped out. Must have a vented cap to run right. truckbummer
