Case 310G's
Larry806
09-28-2003 20:23:29
I bought 2 310G dozers out of a estate The guy bought them both at the same time. Both gas, one has a blade with unknown hours ( not many) The other has loader and 10.9 ORIGNAL hours They both have set out since new I haven't tried but I'm sure the motors are stuck any idea on what there worth? Thank you Larry
src
10-01-2003 05:11:54
 Re: Case 310G's in reply to Larry806, 09-28-2003 20:23:29
We have one, 1959 model, gas, straight blade w/ outside arms, canopy, and a Carco winch. A great tractor. Runs super in any weather. The only weak point is the nut that holds the sprocket on. They like to loosen up, and need to be tightened from time to time (look to see if they've been welded). Going rate for one in our area (N.E.) is $2,500- $4,500, depending on condition.
back40
09-30-2003 04:56:37
Difficult to say what they're worth without seeing them and I wouldn't trust an hourmeter. If they've set out since new, then the transmissions probably have water in them and the tracks are probably froze up. Do you have any photos?
