Pins bushings
Rick Burns
04-23-2001 19:32:57
My JD MC ser #10011 (turf pads, 3 roller)is in need of track work. The track and assembly is in good condition but pads are loose and no adj left in the tracks. What are my options? Where can I purchase parts? Sorry, I'm sure this is elementry to you folks but any assistance is appreciated.
Lavoy
05-01-2001 19:43:05
 Re: Pins bushings in reply to Rick Burns, 04-23-2001 19:32:57
If any of you are ever working on MC's with the carraige bolt pad, I have a heavy washer with a square hole that you can use to repair loose pads. All you have to do is get everything square and tightened up and then run a bead around the perimiter of the washer. This is a far preferable alternative to welding the pads to the rails. If you are going to weld the pads to the rails, make very sure you have good pins and bushings, because MC rails cannot be rebushed in a track press with the pads on.
Also if your bushings have spun in the rails, I can salvage them. It is more time consuming, but at least you can save the expense of coming up with a different set of rails.
Hope this helps,
Lavoy
Rick Burns
05-01-2001 21:13:33
 Re: Re: Pins bushings in reply to Lavoy, 05-01-2001 19:43:05
Lavoy, I'm hopeing to get you to rebush and repin the rails sometime this Summer. The washer method to tighten the pads makes more sense to me than welding pads to the rail. My MC is a great tool. I'll send you a picture. thanks rick
Jerri
04-26-2001 06:25:41
Rick,
Found Lavoy Wilcox's email: llwilcox@earthlink.net
Give him a shout.
Jerri
Possum
04-25-2001 19:30:27
Check your pad bolts, too. They should be grade 8 with NF threads. Soft bolts or coarse threads will always loosen.
Tom
04-26-2001 08:50:28
 Re: Re: Pins bushings in reply to Possum, 04-25-2001 19:30:27
Actually most track pad bolts are grade 12.9 with tensile strength rating of 170,000+ PSI. What used to be called "Fedalloy" comes close to that grade in a regular style (non domed head) bolt. Also, depending on the link style, the nuts are often square.
Hope this helps.
Possum
04-25-2001 19:30:32
Jerri
04-25-2001 13:59:41
Saw that you were looking for Lavoy's info....hope this helps
"For Sale: Parts for MC-440ICD crawlers. Also can rebush your old track chains, or have chains for sale, BO Lindeman through 1010/2010. Call evenings Lavoy 701-281-0398, or Randy 319-729-5641, or E-mail."
drott
04-25-2001 10:01:36
Go to the JD section or the track section on www.ibdozing.com discussion board and you should be able to get Lavoys email address. He is in North Dakota.
He is good
hyoder
04-24-2001 19:02:20
do an enginge serch for lavoy on this website or jd rummeys page he does p&b on these
Rick
04-24-2001 22:20:02
 Re: Re: Pins bushings in reply to hyoder, 04-24-2001 19:02:20
hyoder, I searched on jd rummeys but didn't come up with anything. Is this a web page?
hyoder
04-25-2001 17:51:07
 Re: Re: Re: Pins bushings in reply to Rick, 04-24-2001 22:20:02
Link try this
Half Track
04-24-2001 15:10:16
Rick: S/N will not help on which rail you have. Do you have 2 bolt or 4 bolt pads. That is, 2-5/8" bolt or 4-7/16"(mightbe 1/2", can't remember for sure), but you get the idea. Tom is 100% right about once the bolts get loose, your done holding the pads on just with tight bolts. I don't understand what you mean by track & assemy. in good condition if pads are loose & you have no adjustment. I'm going to guess your links & pads look good but p&b's are shot. The cheapest way is to put new p&b's in the rail & weld the pads on the links. If no to that buy new or damn good used track groups. HT
Tom
04-24-2001 08:28:37
If your pads are loose then the track assembly is NOT in good condition. Once the holes start to "oval" on you, you will have trouble keeping your pads bolts tight. If there is no track adjustment left, your pins and bushings are in need of turning at the very least. If they are so far gone that they are no longer tight in the links then the entire rail would require replacing. Year, make, model and serial are required to identify replacement parts.
Regards,
Rick Burns
04-24-2001 21:52:08
 Re: Re: Pins bushings in reply to Tom, 04-24-2001 08:28:37
Guys, thanks for the info and links. It's a John Deere MC crawler, 1949 ser # 10011. The pads are held to the rails by two bolts. thanks again. rick
