Mac
07-06-2003 16:52:58
Re: manual in reply to Helen Blackaby, 07-06-2003 10:54:52
You also can remove the engine this way, secure the bucket up like Bob said, remove the front and back belly pans, drain the oil and water, take out the two bolts in front of the sprocket holding the track frame to the loader frame on each side, take out the bolts holding the loader frame to the cross beam either side, jack the front of the tractor up, (the tracks should stay on the ground) about four inches or until the bottom of the bellhousing will clear the cross beam, take off the fan guard and remove the rad and housing,undo the bolts holding the tranny cooling pipes and push them down out of the cooler, disconnect all wiring and fuel lines,throttle control,take off the fan to save it getting damaged, take off the air cleaner assembly, take out the row of bolts around the bellhousing and the front engine mounting bolts, there are two tapped holes in the cylinder head so you can screw in two lifting eyes,attach a spreader bar and just take the weight, pull the engine straight out without lifting it any higher till you clear the torque convertor. Good luck Mac
