Re: Gehl CTL60 Rubber Track Loader??? Help!!!
AJ
07-05-2003 02:20:40
That's what you have to do,remove the grease valve,push the idler back,put the track along side the frame,lift it on to the idler,put a bar through the loop at the back and engage it in the sprocket,hold it up at an angle and get a second person to reverse the sprocket and it will go back on,pump it up.
AJ
Jeff
07-05-2003 18:22:36
 Re: Re: Gehl CTL60 Rubber Track Loader??? Help!!! in reply to AJ, 07-05-2003 02:20:40
Thanks for your Help AJ!!! I got her back together with a little help from my brother. Jeff
