I have the luxury of helping a friend out with his Bobcat 610 4 cylinder Wisconsin VH4D and the wiring is a mess. It also has an alternator however, it's not connected to anything. I've been searching for hours to try and find a wiring diagram that works with this key ignition setup. I've provided some photos and I really hope someone can help me out. He told me and I quote,
The little box fell and the wires got unplugged and I tried to fix it but it doesn't start.
We have a new starter coming as the one looked to be overtightened and in result cracked. It was also full of corrosion.
I've found some wiring diagrams that use a switch and a push button but none of them have 7 wires going to the ignition. Here is where I'm stuck and I really hope someone here can help me out. We're at the point where I'd gladly just install a switch and a push button but I honestly don't know where to put any of the wires as he didn't leave anything connected.
I did however find it weird that the head was positive with my power probe and than I found the shortest wire in the middle of my palm resting on the frame. It was hot and after I held it away the head no longer had 12 volts and went back to being a ground. The red light also had no wires going to it. I'm starting to regret getting into this mess.
The best part is, I have a degree in Automotive electrical but let's just say my teacher wasn't a big help (big waste of money) I can fix anything with a computer but I was unfortunately not given the knowledge of older equipment. I'd appreciate if anyone could spare some advice to possibly get this running again.
Thanks,
Conor
Thanks,
Conor
