cat 15 leaf spring
warren frost
09-17-2023 17:23:27
I am restoring a cat 15 crawler tractor and having problem removing the transverse leaf spring supporting the motor.The motor is supported.The u bolt nuts,rebound spring and its linkages have been removed but I cant slide the main leaf spring through the u bolts so that it slides out the side of the machine.Is there anything else holding the spring in place,Icant see anything?Thanks.
NIK OWEN
09-22-2023 17:43:57
 Re: cat 15 leaf spring in reply to warren frost, 09-17-2023 17:23:27
ASK ON ACMOC.ORG...BE BLESSED, GRATEFUL, PREPARED...
AJ.
09-19-2023 05:24:34
I cannot remember the spring set up but by the rule of thumb there must be something holding the spring leaves centre, either a bolt or a dimple, if it's a bolt it might be going through the supplementary spring as well, just my 2 cents.
AJ
