Jd 350b Carb solenoid assembly
Ive searched the web and have been unable to find a solenoid
assembly assembly for a JD350 B crawler.
I have not yet checked with a jd dealer being its the weekend.
Anyone know where I can order one
Thanks
I don't know how you were searching but using the part number AT31877 many sources turn up. The web search shows a replacement available at the YT store (I don't see it listed there, but All States Ag Parts has it so they could get it). They are many others shown. I have gotten them from McDonald Carb and ignition as well. For considerably less money than the solenoid, YT has the parts to install a manually adjusted jet set up in place of the solenoid as does McDonald. I have converted several from the solenoid.
Here is a link to the JD online parts catalog for the 350B.
JD 350B Parts Catalog
(quoted from post at 20:55:30 04/15/23) I came to realize I could open the screw up on the back of the
solenoid and run the dozer
That is correct, but not what you asked about. The operator's manual tells how to do it. Did you reverse the spring and needle, so the adjustment screw holds the needle in against the spring?
