Dresser/Komatsu online parts catalog
RGMartin
Does komatsu have an online parts catalog like other manufacturers?
I need blade lift cylinder seals for my td15E. Normally I would just take them to my local hydraulic shop, but he seems to have taken down his shingle and closed up shop.
I can do the work, but don't have any idea of part numbers.
I didn't find one with a quick search. They may have one, but you might have to go through a dealer to get set up for access. You might try call the Komatsu dealer nearest you.
You may have to search further. As I understand it, IH sold most of the construction equipment division to Dresser. Dresser later joined with Komatsu in a 50/50 joint venture. After a time, Komatsu purchased full control of Komatsu-Dresser Co., renaming the organization Komatsu America International Co. The main part of the crawler line ended up under the "Dressta" brand. They were produced by Huta Stalowa Wola, which had been an IHC licensee in Poland since 1972. Dressta is now a LiuGong brand.
You could try checking with Baum Hydraulics, or other place selling seal kits, to see if they have kits for your cylinders.
Forgot about the Dressta change. That is why I kept just getting the heavy mining stuff when I searched Komatsu. There is actually a large Komatsu manufacturing plant 20 minutes from the house. Nearest Dressta dealer is 4 hours away.
