JD 450 six way blade
I am wanting to install a six way hydraulic blade on my JD 450 that has the mechanical blade now. Does a blade from a 350 fit?? Anyone have a blade and controls they would sell??
(quoted from post at 10:53:49 02/11/23) I am wanting to install a six way hydraulic blade on my JD 450 that has the mechanical blade now. Does a blade from a 350 fit?? Anyone have a blade and controls they would sell??
I will say not without a lot of fabrication and modification. The 350s used a model 6305 inside mount and the 450s used the model 6405 which is larger than a 6305 since the 450 is larger than a 350. For practical purposes it will not fit.
I have a JD 350 manual inside blade with frame & extension arms for manual angle & parts for manual tilt & one (1) hyd. cly. if anyone is interested. In West Virginia. Also have a 6 way hyd. blade for a Case 450B.
Where are you located? I have a straight 450 with a 6 way and all the controls that I have as a parts machine I would be willing to sell. Has a good engine as well. Undercarriage is pretty well shot and bad steering clutches.
It would be quite the road trip Im down in south Louisiana. I could load it on your trailer for you no problem at all I just know that's a long drive. If you are interested my cell is 985-750-6537. Call or text. Devin
