Having problems adjusting steering clutch/brake on a jd 1010c. Basically everything in it is new. The machine is on blocks and the tracks removed. I have followed the service manual to a T. The problem is when it is in gear and the sprockets turning and you pull on the steering lever the corresponding sprocket with not stop turning until the steering handle is nearly all the way back. The steering control rod is backed out quite a bit in order to line up the clutch fingers with the throw-out bearing. The photo shows the position of everything right after an adjustment was made. Do you see anything off ? Would the sprockets stop sooner if the tracks were back on it ? Not enough drag ? Is it possible I missed something or got something backwards when reassembling the brake ban housing ?
