1974 TD7E Dresser
New Dresser owner here. Bought a clean little TD7E, right track was slow to engage on right turn. Iv read enough to find the adjuster on the outside, Iv taken it in about a full turn, still has a couple threads left showing. Taking it in worked and the right side grabs now and feels ok, the left side does seem to grab harder and quicker when pulling on the stick to that side, it s almost a jerk, should I back the left side off to match the right, Iv have also noticed it tracks to the left slightly, I was thinking someone might have cranked the left side in to far and could be causing it to track left. I ll clean mud out of the way and inspect to see if both sides are close to the same. With all this said I m searching for the correct procedure to adjust. I have read to take it all the way in till it s firm and back out a half turn, and I ve heard full turn for extra clearance. Any advice would be helpful.
Just too much to type here nd you need to understand exactly what you are doing. will be glad to
talk you thru it . My e-mail is open just click and send me a good phone number and I will call you
well let's go another direction in the block up in you right hand corner open your e-mail and I will
send you and e-mail I just am not about to put my phone number out here in the open I definitely
can talk you thru it but you need to understand and get it right as I said just too much to type
takes 4 pages in the service manual.
Looks like you might be right here close I am on the sw corner of ft Campbell at Dover Tn . We need
to hook up I have a lifetime experience on the ih crawlers.
Don't know any thing about it. Just down
the road from JM. I do have somewhere you
can play with it though! If you do meet up
for lunch Jerry let me know. I might join
you.
In oklahoma now lived in Hopkinsville KY and Clarksville TN, from 2007-2012, then off to FT Bragg NC till 2016 now currently in Oklahoma. Seems my handle is my email if you d like to swap contact info that way, since I can t figure out classic view or how to open my email to be viewed. You re the only reply I can t see the email select tap on. Touch basis with my email and when the snow here melts and the mud in the tracks isn t like a rock I ll get it cleaned up and schedule a phone call with you.
I m in Oklahoma currently was only at for Ft Campbell 5 years them off to Ft Bragg NC. Do you know of anyone with a lead of transmission parts, I m looking for the output seal for the driveshaft.
Common seal probably have it here but take the old one with you to any good parts /seal store .
Well sure would like to help but have tried that e mail ever way in the world and it keeps coming
back. You should be able to just click on my e-mail here as a reply and send me a phone number.
Jerry Watkins 12 am 2/3
