Dieseltech
- Location
- Akron, Indiana
I have a question about a Genie 5519 telehandler with the Deutz 2011 four cylinder diesel. I want to replace the engine timing belt. I have the new belt, idler, crank and
cam locating pins. Question is will the radiator need removed, or will it tip away from the engine enough after the support bolts are removed for fan/pulley removal
that's bolted on the front of the crank? It LOOKS like there's enough room with it tipped but I'm not sure.
Thanks in advance.
Thanks in advance.
