JD 440 ic bottom rollers
I bought a 1959 JD 440 oc
took it to my mechanic that only works on crawlers and skidsteers
He said the bottom rollers look good except for one that should work but should look at replacing it or
maybe all of them on the one side
Final drives are good, bands are new, motor is fine as are hydraulics.
Where can I get some used rollers?
(quoted from post at 11:17:46 11/29/22) I bought a 1959 JD 440 oc
Check with Lavoy at jdcrawlers.com. You could check with YT to see if any of the All States Ag Parts yards have some (or directly call their yard nearest you to check). Giving your general location might get you some leads near you.
they can be built up with weld if the shafts and bushings are ok--i have done many of my own--including the idlers
