Company Logo (800) 853-2651 Shop Now
Cat D4 6u Zenith carburetor query
Laddie1012
11-23-2022 23:58:53
Hi guys.
I have a Cat D4 6u dozer started with petrol pony ...the Zenith carb is a TC4 model.
I have a problem with the mains jetting setup inside the carburetor float bowl.
There's a 2" long needle about 4mm diameter that is the mix adjustment needle.
At the moment the needle is sitting too high so the mix is way too rich and the pony is smoking and under powered...makes starts difficult. It will turn the diesel over uncompressed but will stall if the decompression is disengaged.
Some TC carburetor have this needle as a direct screw.
Mine has a spring load setup that I can't easily figure out.
The spring is lifting the needle out from the seat.
The mechanism to push down seems to be missing something.
Any ideas? Even bad ones...
AJ.
11-24-2022 17:26:45
 Re: Cat D4 6u Zenith carburetor query in reply to Laddie1012, 11-23-2022 23:58:53
Try the carburettor shop at the link below for a repair kit, I do not know if all the parts you want are in the kit so check before you buy.
AJ
Link
NIK OWEN
11-24-2022 16:15:21
PUT IT ON SHELF, OR BURY...GET A RIDING MOWER CHINESE CARB, GET MUFFLER SHOP 2 WELD U A 90 DEGREE FLANGE MOUNT...IT WILL ALWAYS WORK, & RITE...BE BLESSED, GRATEFUL, PREPARED...D69U
dpendzic
11-24-2022 07:55:23
there are two types of main adjusting screws---one is the vertical screw that directly moves the needle up or down and the other is a horizontal screw that pushes on a 90 degree lever which lifts or lowers the needle---the lever often gets bent throwing the adjustmet off
Today's Featured Article - Sunday Drives - by Cowboy. Summer was finally upon us here in Northern Maine. We have two types of industry up here, one being "Forestry" (Wood Products) and the other "Farming" (Potatoes). There is no shortage of farm tractors and equipment around here! I have been restoring old Farm Tractors for the past 6 years, and have found it easier and less expensive to hit all the auctions and purchase whole tractors for parts needed. My wife who works at a local school, and only has weekends and summers off, while on t ... [Read Article]
Latest Ad: Looking for a operator platform to fit a 1070 case tractor. Part number is A 62150 old number is A60672. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
