Case 530CK Hydraulic Quick Coupler Question
EdZeb
New User
I have 530CK and need to replace the hydraulic quick coupler that is under the valve bank of the front bucket. It is the coupler that connects one of the hoses to the backhoe. I am told by local farm supplies that it is the older Case 'smooth' style. Does anyone know if they are still available and where I could purchase one? The hose end of the coupler is 1IN NPT. I have not yet removed the other end that is still on the front bucket control valve bank.
Why do you want to change the coupling, is it damaged or just leaking, if its leaking it's only an o'ring that can be replaced, any one inch coupling will fit but you got to change both the male and female, different makes of couplings will not interchange with each other that,s why both ends has to be changed, you will find the parts #'s in the online parts list that suits your serial #, I would go to the hydraulic shop first.
AJ
