Several people on the forum have given me suggestions which I appreciate. Removed small cover plate and sprayed things under the cover with blaster. Will use my 9/16 end wrench with a wire attached to it in case it slips out 0f my hand to loosen the adjuster lock
Is it neessare to remove the nut and small adjuster? looks like enough space to loosen nut and use a small screw driver to move the latch for the aduster ring back out of the way.
Not much room to tap on one of the metal extrusions. Have a long screw driver but it would cut the metal. Will get a 3/8 in piece of solid rod to tap the extension on the adjuster ring.
Might the following loosen things? put dozer in gear 3 and push into a large dirt pile to try and loosen the cluth. Would do this with clutch lever partially engaged. Would appreciate any follow up members on the forum could let me know if I am on the right track. Removing the clutch when I am 80 years old is probably too much for me
